xztraz
#1 Posted : Sunday, May 2, 2021 8:46:53 PM(UTC)
xztraz
Sweden
Support for external controllers for color corection is somewhat ready but there are some major things making it not really usable.
If adjusting for example red level. and then adjusting the overall gain. the red level is reset. that is not the way it should work.
SetCCGainRGB, SetCCGainR, SetCCGainB SetCCGainG does not work well together. (probably the same for lift)
so again..
say you want to color correct an input with a bit more red(SetCCGainR). and then set the white level(SetCCGainRGB). then the SetCCGainRGB gain overrides the Red gain and resets the color correction.
so you can't use the gain parameters as a basic color correction tool from an external controller.
they should be independent as in every bing controller there is.
thanks 1 user thanked xztraz for this useful post.
Xavi137 on 6/12/2021(UTC)
Xavi137
#2 Posted : Saturday, June 12, 2021 2:21:51 AM(UTC)
Xavi137
so again..
This is very important
Xavi137
#3 Posted : Saturday, June 12, 2021 4:16:55 AM(UTC)
Xavi137
News...
Doing various tests I found a very good solution
by the way greetings to all is my first message.
Two months ago I did not know anything about VMIX and now I consider myself PRO
It's a bit of a mess at first, but it gives extra advantages such as sensitivity and gain or RGB travel adjustment.
I will try to synthesize.
The source to retouch is created as a copy with "virtual input".
This new source image of the first one is deactivated to follow the colourimetry of the first one "use source settings".
Only "SetCCGainRGB" is assigned to the original source. To the virtual copy "SetCCGainR" and "SetCCGainB".
The virtual copy is assigned a percentage of alpha, for example half. This value adjustment is important to give more travel to the colourimetry or to the master gain, whichever you prefer.
Lastly, the initial source, which will actually be selected as the switchable source. The virtual input is assigned as a layer.
That is all. Master Gain setting that does not reset the colourimetry + GAIN and RGB path setting.
eduardocfs
#4 Posted : Saturday, June 12, 2021 4:28:19 AM(UTC)
eduardocfs
Brazil
Originally Posted by: Xavi137 Go to Quoted Post
News...
Xavi137, send more informations and photo.
Xavi137
#5 Posted : Saturday, June 12, 2021 4:38:21 AM(UTC)
Xavi137
News...
And you have a solution. I have edited the message.
Next days I will make 5 unresolved questions
xztraz
#6 Posted : Tuesday, June 15, 2021 10:08:52 PM(UTC)
xztraz
Sweden
this should be fixed properly instead of hacking around it.
