raugert
#1 Posted : Thursday, April 4, 2019 1:08:13 PM(UTC)
raugert
Canada
Was thanked: 216 time(s) in 125 post(s)
vMix has a very powerful Scripting feature, but some folks are not so comfortable with coding, and may not be using scripts to their potential. So.. I made a little app that is simple to use and that will build the script for you.
Features:
- Simple to use with pulldown menus that reflect your inputs when connected to vMix.
- Build scripts offline by manually inserting the pertinent vMix info into the pulldown fields (such as: Input Name or number, Selected Name, Index, etc) . This can be useful if you often use the same input names for different vMix presets.
- Import scripts and modify them to suit your needs
- Export (save) the scripts for use in vMix or other 3rd party programs
- Quickly test your scripts as you go ! (It's not necessary to save and import them into vMix to test them). Just press "Test Script" button
If you have never written a script, I would encourage you to read the "Shortcut Function Reference' chapter in the vMix User guide to understand how to use the commands.
Screen Shot 2020-02-26 at 12.18.55 AM.png (108kb) downloaded 27 time(s).
Here's the link for those who wish to give it a try:
https://cli.re/vMix-Script-Builder-1.0.7
cheers,
Richard
thanks 27 users thanked raugert for this useful post.
ThommiTechnik on 4/4/2019(UTC), stevespaw on 4/5/2019(UTC), pba on 4/5/2019(UTC), Video Dave on 4/5/2019(UTC), AVStream on 4/9/2019(UTC), it-rttv on 4/9/2019(UTC), islyakh on 4/9/2019(UTC), echobb on 4/17/2019(UTC), kevev on 4/17/2019(UTC), QuiapoChurch on 4/21/2019(UTC), Teye on 4/27/2019(UTC), avsoundguy on 4/30/2019(UTC), Jurgen on 12/18/2019(UTC), studiodelta on 2/3/2020(UTC), Peter1000 on 2/21/2020(UTC), tkachuk.alex on 2/24/2020(UTC), clafarge on 3/25/2020(UTC), sinc747 on 3/25/2020(UTC), KnightHeart on 4/23/2020(UTC), SimpleAOB on 5/3/2020(UTC), seb666 on 6/29/2020(UTC), billh2020 on 8/27/2020(UTC), Eddy Vanuytven on 11/4/2020(UTC), YaltaProduction on 11/9/2020(UTC), AVolutionPro on 11/21/2020(UTC), Vyacheslav on 2/7/2021(UTC), DaleH on 2/28/2021(UTC)
raugert
#2 Posted : Friday, February 21, 2020 2:26:10 AM(UTC)
raugert
Canada
Updated version 1.0.4 (link in first post)
- added Mix feature from vMix23
- changed Input data to reflect "Input Name" rather than GUID. Can now be used on vMIx presets that use common names.
Richard
tkachuk.alex
#3 Posted : Monday, February 24, 2020 11:13:31 PM(UTC)
tkachuk.alex
Ukraine
Super app. THX. But could you add Cyrillic support. Names and data now are "???????"
TNX once more
Peter1000
#4 Posted : Tuesday, February 25, 2020 5:59:59 AM(UTC)
Peter1000
Switzerland
Was thanked: 42 time(s) in 33 post(s)
Cool Tool, it would be nice, if we could copy the compiled script text to the clipboard.
Thanks for your effort.
Peter
raugert
#5 Posted : Wednesday, February 26, 2020 5:14:19 PM(UTC)
raugert
Canada
Update v1.0.6 (link in first post)
- added french and cyrillic support
- choose vMix Scripts for use in vMix scripting settings or
- choose URLEncoded Scripts for use in browsers or 3rd party apps
- "import" button will import vMix scripts that were created in vMix scripting
- "save" button will save vMix scripts for importing directly into vMix scripting
- fixed incremental += in value field not always working correctly
- "new command” line now appears when clearing script
- added copy to clipboard feature
Richard
thanks 1 user thanked raugert for this useful post.
JAIRODJ
#6 Posted : Thursday, February 27, 2020 6:21:20 AM(UTC)
JAIRODJ
Was thanked: 13 time(s) in 9 post(s)
Hi
I would like to check if possible, use the command
"waiting for completed"
This command is in an example in the vmix forum, but I can't make it work.
What I want is that when you finish playing the video the following script command is executed.
Function = Fade & Input = Alex Ubago - Look at us.mp4
waitingForCompleted
Function = Fade & Duration = 100 & Input = NDI AIR2 (vMix - Output 1)
I've tried many ways but I can't do it with the script.
Can you help me please.
raugert
#7 Posted : Thursday, February 27, 2020 7:52:39 AM(UTC)
raugert
Canada
Use this Script Builder app to create the script for you . Then copy to clipboard and paste it in vMix scripting.
It should look something like this:
Function=Fade&Input=Alex Ubago - Look at us.mp4
Function=WaitForCompletion&Input=Alex Ubago - Look at us.mp4
Function=Fade&Duration=100&Input=NDI AIR2 (vMix - Output 1)
regards,
Richard
Joeboe
#8 Posted : Tuesday, August 11, 2020 9:48:49 PM(UTC)
Joeboe
Was thanked: 23 time(s) in 22 post(s)
Hi, I am trying to make a scoreboard for the game of cricket...I have all the batsmen scores advancing correctly, but I can not get the individual scores to total....can anyone point me in the right direction....in other words, if each batsman make 25 runs, and there are 4 batsmen, each time a batsman make a run, and I add that to his score, I want to see it reflected in the total for that team...( batsman 1= 20 runs, batsman 2= 24 runs: Total =44....)... I am not a script writer, so I need an example to work with....any help will be surely welcomed.....
Thanks in advance
westis
#9 Posted : Saturday, October 10, 2020 1:22:50 AM(UTC)
westis
Sweden
This looks great! However, website not accessible, can't establish a secure connection. Could this be fixed so it's possible to look at and download the app?
raugert
#10 Posted : Saturday, October 10, 2020 1:47:30 AM(UTC)
raugert
Canada
It is a redirected link to a dropbox download. I can download OK on Safari. Maybe try another browser. If you still can't download it, please email me at info@studio793.ca and I will give you a private link to try.
regards,
Richard
Martin Block
#11 Posted : Saturday, October 17, 2020 1:57:55 PM(UTC)
Martin Block
Philippines
This is a fantastic tool!
I tried it for the first time - not knowing my way around scripts at all - and I was able to easily create various scripts for managing audio talk-back with several vMixcalls. This will save me so much work!
Thanks for sharing this!
thanks 1 user thanked Martin Block for this useful post.
Jurgen on 10/31/2020(UTC)
raugert
#12 Posted : Wednesday, November 18, 2020 2:22:24 AM(UTC)
raugert
Canada
UPDATE: Version v1.0.7 (see first post)
- Added "DataSources" to command pulldown menu
- Changed URLScript to display URL Encoded format
- Added vMix Port field
- Added compatibility with Windows and Mac files (Exported Mac Catalina files wouldn't always load properly on Windows)
Richard
David_in_Philly
#13 Posted : Tuesday, December 8, 2020 12:59:08 PM(UTC)
David_in_Philly
Was thanked: 9 time(s) in 6 post(s)
So great that you created this, Richard. Thank you. I can't wait to start using it.
Have you ever considered a version that can output VB script - for those of us that need scripts that may not be possible using vmix's built in scripting function?
For example, I've been doing a lot live, 4K overshooting lately - without any camera people. Each of three cameras is framed so that we can get 3-4, 1080p shots (or 4 720p shots) which you use on one main and 3 virtual inputs. So for camera 1, our inputs are 1-4 (1A,1B,!C,!D). The problem we are trying to address is tally lights. Right now, the talley only turns red when input 1 is in program. Inputs 2-4 don't trigger camera-1's talley, but need to, given that virtual inputs 2-4 also come from camera-1.
I'd love to be able to write a script that tells Vmix that anytime inputs 2-4 are routed to program, turn on the talley for camera-1 (as well as when input-1 is similarly routed) - and a similar script for preview routing.
It seems to me that this is something that's beyond the scoped of basic Vmix scripting, but perhaps not for VB scripting.
Any thoughts?
raugert
#14 Posted : Tuesday, December 8, 2020 1:49:24 PM(UTC)
raugert
Canada
The Script Builder app was designed to build vMix Scripts (which I would call "linear" scripts), where one event is triggered after the other . VB.net scripting can be more like "conditional" scripting, where you can apply certain logic. It would be impossible to make this app answer individual needs of "conditional" scripting. There is a good thread about VB.net scripting on this forum that might help you write your script. ( https://forums.vmix.com/...86-Scripting-for-Dummies )
I'm curious what system you are using for the tally lights ?
cheers,
Richard
David_in_Philly
#15 Posted : Thursday, December 10, 2020 4:44:03 PM(UTC)
David_in_Philly
Thanks, Richard.
So far I’’m just using vmix’s internal tally light system and smartphones pointing to either a local copy of Vmix or a remote copy over the Internet.
Best,
David
If you know anybody who is interested in Vb.net scripting for Vmix, I’d love to have access to an ad hoc developer - either on an hourly or project basis.
Much appreciated!
