UPDATED: 1 Feb 2019Use this App to design your own Custom Control Panels. It is fully customizable and works on PC, MAC and All-In-One or Laptop touch screens.
Features:- Window can be sized to whatever you like. Make large panels for multiple functions or small panels for simple functions.
- The background "theme" is selectable
- Buttons can have the "Classic Switcher" Clear button look or Coloured buttons with adjustable border size or Icon Buttons with customizable icons.
- Resizable Buttons, Labels and Faders can be added to canvas. Clone single or multiple objects.
- vMix Commands can be placed directly in Buttons and Faders
- "Hotkeys" - Keyboard keys can be assigned to Buttons
- Timer feature to send Button commands at a specified time (one time trigger)
- Objects can be be sized and placed wherever you like on the canvas by drop and drag. Button/Label colours and border sizes can be adjusted to suit users.
- Labels can be placed on top or behind objects and made opaque or transparent. Border size, Text size and Colour is adjustable.
- Faders can be be sized and placed wherever you like on the canvas. VU's can be hidden in Preferences if desired.
- Buttons and Faders can be assigned to any vMix commands (All the vMix shortcut commands are available on dropdown menus)
- Run vMix scripts directly within app using the "Script Builder". No need to know programming
- The layouts can be saved for later use. They files are not encrypted so they can easily be shared with others.
- No need to program the midi shortcuts in vMIx.
- Can be used on local network (LAN) or DDNS if you wish to control from outside your network (requires DDNS server)
Download Links:
Version 2.0.36 (updated 1 Feb 2019)https://cli.re/vmix-panel-builder-v36User Guidehttp://cli.re/vmix-panel-builder-user-guideSample Templates:http://cli.re/vmix-sample-templates Screen Shot VMPB Volleybal.png
(1,112kb) downloaded 7 time(s).*** DEMOS/TUTORIALS ***Pt 1 - Intro to vMix Panel Builder:
Pt 2 - Adding objects into Panel Builder:
Pt 3 - Adding command to objects:
Pt 4 - Adding scripts to buttons:
