2 Pages12>
vijay6672
#1 Posted : Thursday, May 17, 2018 2:49:14 PM(UTC)
vijay6672
India
Was thanked: 17 time(s) in 9 post(s)
vScheduler 24x7 Build 2018.09.30 Released.
Visit: http://www.sitescape.co.in
Change Log:
Build 2018.09.30:
Get Title/Duration by I/P No. for:
I/P | LIST, Remove I/P, Overlay (1-4) Tgl/In, Set IMV, IMV On, IMV Off, IMV Tgl, Set Image, Set Text, Text Colour, Count Down.
Loop Off/On for I/P | LIST, Start PlayList
Start PlayList
Stop PlayList
Independent Stream Control for Start/Stop/Tgl Stream (Requires vMix 21+)
Zoom/PanX/PanY for Xaml, I/P | List
Updated Shortcut Keys for KeyPress
To Excel changed to Save .XLS
Minor Changes in UI
Minor Bug fixes
Updated Help file
I/P | LIST, Start PlayList - Limitations:
If vMix/vScheduler 24x7 stops by any means, After restarting vMix/vScheduler 24x7, there is no option to retrieve current event in vScheduler 24x7
Build 2018.08.30:
Add PowerPoint Presentation
Add any HTML Colour (In place of "Add Black")
Set Zoom, PanX, PanY Settings for Video, Image, Photos, PowerPoint & Colour
Revamped UI
Removed Time Presets
Fixed Transition time
Get Duration Button for vMix I/P
Check New Version / Update
Minor Bug fixes
Build 2018.06.30:
Change Default IP Address (127.0.0.1)
(Now, vScheduler 24x7 can also run from a separate PC on the same network from the one with vMix installed**)
Fixed vController Settings not saving automatically
Build 2018.06.14:
(Since last version of MacJaeger)
New functions addition:
-Add Xaml file
-Overlays (1-4) In/Out/Off/Zoom/Toggle
-InputMultiView Set/On/Off/Toggle
-Recording On/Off/Toggle
-Streaming On/Off/Toggle
-External Output On/Off/Toggle
-Scripts Start/Stop/Stop all/Dynamic On/Dynamic Off
-Snapshot
-Set Text
-Set Text Colour
-Set Image
-Countdown To
-KeyPress
-Remove Input
New transition effects addition:
-Merge
-VerticalSlide
-VerticalWipe
-SlideReverse
-WipeReverse
-VerticalSlideReverse
-VerticalWipeReverse
Fixed Photos-Slideshow not playing automatically
Fixed Next file Transition/Playing little early
Save schedule to Excel sheet
Fixed some bugs
vijay6672 attached the following image(s):
vScheduler 24x7 - vManager.png (68kb) downloaded 3 time(s).
vScheduler 24x7 - vController.png (55kb) downloaded 2 time(s).
thanks 8 users thanked vijay6672 for this useful post.
jakefilmpro on 5/17/2018(UTC), tkachuk.alex on 5/18/2018(UTC), AVStream on 5/21/2018(UTC), rowby on 5/23/2018(UTC), avsoundguy on 5/27/2018(UTC), liwarnyamannya on 6/3/2018(UTC), FoxICT on 6/13/2018(UTC), ON.tv Channels on 6/20/2018(UTC)
AVStream
#2 Posted : Monday, May 21, 2018 7:11:15 AM(UTC)
AVStream
Is there any support for NDI, or it uses vMix API functions?
Cant wait for a demo )
vijay6672
#3 Posted : Monday, May 21, 2018 11:53:41 AM(UTC)
vijay6672
India
Based on vMix API functions.
thanks 1 user thanked vijay6672 for this useful post.
jelutalica on 5/22/2018(UTC)
sosparabolicas
#4 Posted : Wednesday, May 23, 2018 9:48:23 AM(UTC)
sosparabolicas
When will you make Download available for testing?
vijay6672
#5 Posted : Thursday, May 24, 2018 2:20:24 AM(UTC)
vijay6672
India
Currently under beta testing and expected release date is 30th may.
thanks 2 users thanked vijay6672 for this useful post.
Lennart
#6 Posted : Saturday, June 2, 2018 4:44:04 PM(UTC)
Lennart
Looking forward to it! :)
Nikolay
#7 Posted : Thursday, June 7, 2018 9:14:31 PM(UTC)
Nikolay
The required functions are declared.
very much waiting for release
pabenic12
#8 Posted : Friday, June 8, 2018 8:55:28 AM(UTC)
pabenic12
Any update on release date?
JimJacobs
#9 Posted : Sunday, June 10, 2018 2:32:31 PM(UTC)
JimJacobs
Any idea when this is happening?
sosparabolicas
#10 Posted : Monday, June 11, 2018 11:45:14 PM(UTC)
sosparabolicas
When Will We Have The Download Link?
vijay6672
#11 Posted : Tuesday, June 12, 2018 1:22:54 PM(UTC)
vijay6672
India
Demo version will be released within 1 week
FoxICT
#12 Posted : Wednesday, June 13, 2018 8:20:22 PM(UTC)
FoxICT
Hi Vijay.
It would be an excellent feature to have vScheduler "Loop" the playlist with a toggle button.
Otherwise, look forward to the excellent update in the coming days.
vijay6672
#13 Posted : Tuesday, June 19, 2018 1:26:34 PM(UTC)
vijay6672
India
FoxICT wrote:
Hi Vijay.
Will think over the possibilities.
vijay6672
#14 Posted : Thursday, June 21, 2018 2:40:51 PM(UTC)
vijay6672
India
vScheduler 24x7 Build 2018.06.14 Released.
Build 2018.06.14 Change Log:
-Add Xaml file
-Snapshot
-Set Text
-Set Text Colour
-Set Image
-Countdown To
-KeyPress
-Remove Input
-Merge
-VerticalSlide
-VerticalWipe
-SlideReverse
-WipeReverse
Fixed some bugs
FoxICT
#15 Posted : Thursday, June 21, 2018 2:57:55 PM(UTC)
FoxICT
vijay6672
#16 Posted : Thursday, June 21, 2018 3:00:55 PM(UTC)
vijay6672
India
FoxICT wrote:
FREE Demo version (Limited Features - Unlimited Time) available.
Visit: http://www.sitescape.co.in/downloads.html
#17 Posted : Sunday, June 24, 2018 10:11:59 AM(UTC)
Was thanked: 515 time(s) in 414 post(s)
Hi Vijay
before I try your app, 2 questions:
- will it work on a different host than the vMix one ? Meaning can we set the vMix host IP address to be used or it is only designed for 127.0.0.1 ?
- does it support UNC path for files ? Example, can I use it on PC1, vMix being PC2 and media being stored on a NAS server (PC3) - eventually on a mapped network drive/folder ? Preferred UNC being \\SERVER\SHARE\FOLDER\FILE, instead of x:\\share\folder\file
Thank you
Guillaume
vijay6672
#18 Posted : Monday, June 25, 2018 2:05:33 PM(UTC)
vijay6672
India
127.0.0.1 is hard-coded in present version;
Different host... will be implemented in next version.
Yes, It supports UNC Path.
Charssay
#19 Posted : Monday, June 25, 2018 4:52:38 PM(UTC)
Charssay
Was thanked: 17 time(s) in 17 post(s)
Any One did try it Up ?
How he goes ?
Vijay, 75 USD for the licence it's a little be expensive, did you think ?
Your demo, how many time it last ? It's a fully working demo or some set will not work ?
Thx
vijay6672
#20 Posted : Tuesday, June 26, 2018 5:57:31 PM(UTC)
vijay6672
India
Will think again about that.
Limited Features for Unlimited Time.
2 Pages12>
