Feature Requests
Add "Fine Adjustment" Buttons to the Color Correction Filter
Joined: 3/3/2025(UTC) Posts: 31  Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Hello, I really appreciate the Color Correction filter on inputs. I often use it in the transition from sunlight to night time lighting. It is great but it is really difficult to make fine adjustments by moving the small circle in the color wheel. So I would suggest adding + and - buttons by each wheel. So one can click for precise movements. Also, add the ability to type in the value boxes. I have attached screenshots of how it is now and how I envision adding the buttons. Thanks!  Vmix Color Correction 1 Original.png (942kb) downloaded 19 time(s). Vmix Color Correction with Buttons.png (754kb) downloaded 19 time(s).
Joined: 11/14/2012(UTC) Posts: 357  Location: Finland Thanks: 223 times Was thanked: 23 time(s) in 21 post(s)
Joined: 12/8/2022(UTC) Posts: 158  Thanks: 48 times Was thanked: 3 time(s) in 3 post(s)
Feature Requests
