calamityjane
#1 Posted : Tuesday, April 7, 2026 8:37:12 AM(UTC)
calamityjane
It appeared to me that in the output settings you could assign which overlays went with each output. Doesn't seem to be the case.
Is there a relatively simple method to apply different titles to both streams?
Whit
#2 Posted : Tuesday, April 7, 2026 7:30:44 PM(UTC)
@ calamityjane
The Overlay options in Output settings only apply to the main vMix Program Output, so for example, if you want Overlay 1 to only appear on Output 1 and Overlay 2 to only appear on Output 2, then both Overlays need to be enabled and on screen in vMix and then in Settings, both Outputs need to be set to "Output" and Overlay 2 needs to be disabled on Output 1 and Overlay 1 needs to be disabled on Output 2.
If you are instead sending different content to each Output then those Overlay settings don't apply so you will need to configure things differently and use Mix Inputs with specific Inputs and Overlay channels assigned to them in Shortcuts.
quixoticla
#3 Posted : Wednesday, April 8, 2026 12:45:23 PM(UTC)
quixoticla
Yeah, unfortunately there isn’t a built-in way to assign different titles per output directly. A common workaround is to run two separate instances or use different scenes/overlays tied to each stream output if your setup allows it.
Not the most elegant solution, but it gets the job done until they add proper support for it.
