#1 Posted : Sunday, November 9, 2025 9:13:46 PM(UTC)
Was thanked: 1008 time(s) in 830 post(s)
After successful setting up a Raspberry Pi OMT Player booting up automatically to the service I like to know how to stop it from booting up or in general stop the service and go back to the Desktop mode
Raspberry is new to me (but fun ;-) )
Tnx
#2 Posted : Sunday, November 9, 2025 11:15:41 PM(UTC)
Was thanked: 4614 time(s) in 1596 post(s)
To go back to desktop, you can reverse the steps to set it to console.
sudo raspi-config
Find the options in the menus:
1 System Options
S5 Boot
And select the desktop option instead of console
To disable the service:
sudo systemctl disable omtplayer
#3 Posted : Sunday, November 9, 2025 11:24:18 PM(UTC)
sudo raspi-config
1 System Options
S5 Boot
My problem is how to get into the console in the first place while the OMTplayer is running or avoid it starting at bootup and go to the console
#4 Posted : Sunday, November 9, 2025 11:36:54 PM(UTC)
OK, found a way:
Stop (disconnect) any OMT feed from reaching the Raspberry and reboot it (Ctrl-Alt-Delete) , will end up with an accessible console and let me do sudo raspi-config to change the boot selection
Guest (5)
