avsoundguy
#1 Posted : Wednesday, August 27, 2025 8:40:03 AM(UTC)
avsoundguy
I set my audio input to have no mouse click action to keep from accidentally putting a black screen into my workflow. v29 still has that same capability and it works as expected, the New GO button action is set to do Nothing within the settings but the indicator on the input shows Prv and indeed it does put the audio input into preview so the indicator showing Prv does not match the settings which I have chosen which is do Nothing.
Thanks for your kind attention to this issue.
v29 GO issue.png (14kb) downloaded 28 time(s).
#2 Posted : Wednesday, August 27, 2025 9:23:27 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
The Prv button replaces Cut and has always done this when you set the Mouse Click Action to Nothing.
As you can see in the screenshot the GO button is still there and will do nothing when set to Nothing as expected.
