2 Pages<12
mavik
#21 Posted : Sunday, January 5, 2025 12:25:46 AM(UTC)
mavik
Was thanked: 170 time(s) in 152 post(s)
Then the only chance I see is to add virtual inputs of that input (right click the cog buttom right of the input) and crop the virtual inputs to sections you want to have. Then combine these virtual inputs in layers to a whole again. Use that final input as the overlay.
Mari
#22 Posted : Sunday, January 5, 2025 12:30:59 AM(UTC)
Mari
Netherlands
Originally Posted by: doggy Go to Quoted Post
Add Input, select color and select transparent
then add as layer the captured input on the colored one <g>
Tried that, Color input, transparent and put the desktop capture on as a layer... same result... all what has to be transparent is black...
Mari
#23 Posted : Sunday, January 5, 2025 12:36:07 AM(UTC)
Mari
Netherlands
That is what I did in the past... this app should make it easier...
malikwillim1122
#24 Posted : Sunday, January 5, 2025 9:55:22 AM(UTC)
malikwillim1122
Pakistan
To get a generated overlay in a window in vMix, update to the latest version. In vMix v21, the issue may be resolved by updating the software. Once updated, you can add the overlay by selecting the desired media or graphic and placing it in the appropriate input or overlay channel.
#25 Posted : Sunday, January 5, 2025 11:41:31 AM(UTC)
Was thanked: 967 time(s) in 801 post(s)
Tell us you didnt read the previous comments by not saying you didnt read the previous comments '-)
2 Pages<12
