Beta Discussion
Bug: virtual set setup UI regression (FIXED)
Joined: 2/23/2023(UTC) Posts: 60  Thanks: 13 times Was thanked: 11 time(s) in 4 post(s)
The Layer and Input drop downs inputs on my Virtual Set look smaller and less legible in v28.0.0.25 compared to v27. My monitor resolution is 3840x2160 with 200% scaling. There is no difference between switching on and off the High DPI override described in the KB.  vmix_28_0_0_25.PNG (9kb) downloaded 2 time(s). Capture2.PNG (8kb) downloaded 2 time(s).
Also related is the "Create Input at this Position" button being clipped:  Capture.PNG (8kb) downloaded 3 time(s).
Joined: 1/13/2010(UTC) Posts: 5,213  Location: Gold Coast, Australia Was thanked: 4485 time(s) in 1564 post(s)
Update: You're right that the virtual set dropdown text could be bigger.
Update: Looks like the PTZ buttons text may not fit with scaling 200% or higher, so we'll get that fixed.
Beta Discussion
