My environment is 28.0.0.25. The network automatically obtains IPv6 addresses through the operator. Both computers have turned off firewalls and can ping. In order to verify that the network is available, the network controller is used to turn off LAN access only. Access through the IPv6 public network address is possible. When testing the SRT stream, it was found that the IPv6 SRT stream can only be decoded locally and cannot be decoded through the network. The public network test used one 5Gcpe and the other used a wired network, and the test failed. We adjusted the two vmixes to a local area network, and the SRT stream could not be connected through IPv6.
Joined: 10/31/2020(UTC) Posts: 182  Thanks: 4 times Was thanked: 42 time(s) in 41 post(s)
I just tried this on my network. My ISP gives me public IPv6 addresses, so my network is fully IPv6 capable.
Using ffmpeg and ffplay, I was able to send SRT over the internet to a computer on my network over IPv6 and it plays (via ffplay). Stopping ffplay and starting vmix with an SRT listener input on the same port, no joy. ffmpeg says it can't connect. I then tried it on my LAN from one computer to another. Again, ffmpeg to ffplay works fine over IPv6, ffmpeg to vmix won't connect (via IPv6).
Joined: 1/13/2010(UTC) Posts: 5,212  Location: Gold Coast, Australia Was thanked: 4485 time(s) in 1564 post(s)
Please contact support directly, so we can check what settings are used, also in your email please describe the exact command line you used in other tools successfully. https://www.vmix.com/contact-us.aspx
