Beta Discussion
Stream Indicator in UI limited to 3 streams (FIXED)
Joined: 12/19/2019(UTC) Posts: 54  Was thanked: 26 time(s) in 18 post(s)
While vMix now supports 5 separate streams, the indicator in the UI above the program output only shows 3 streams, and seemingly the 3 lowest number streams. For example if Streams 1, 3, 4, and 5, are all live, it will show STREAM 1, 3, 4. If stream 2 was started then it would show STREAM 1, 2, 3 and 4 would no longer be shown despite still being live.  vMix64_8o6EegMixa.png (5kb) downloaded 2 time(s).
Beta Discussion
