Beta Discussion
Outputs information added to API XML-SRT information and Outputs appear or not in the API (FIXED)
Joined: 12/24/2021(UTC) Posts: 692  Location: athens Thanks: 159 times Was thanked: 86 time(s) in 82 post(s)
Hello. I see in the API xml the outputs. When we have in a output the NDI ON it says <output type="output" number="1" source="Output" ndi="True"/> and if we close the ndi on this output and refresh the 127.0.0.1:8088/api immediatelly it changes to <output type="output" number="1" source="Output"/> For SRT the API says <output type="output" number="1" source="Output" srt="True"/> but even if we disable it or stop transmitting and then refresh the api page it continues to say <output type="output" number="1" source="Output" srt="True"/> and it doesnt change to inform us that we dont srt out from this output. If we close vmix and then open it and have srt outs disabled, it reads correctly that srt is not transmit. To me seems like this value somehow is not realtime informed Is this only me,by design or bug? Thanks for any answer
Also i think a bug with the outputs section in the API how they appear or not.Im attaching some photos from the vmix--->settings-->outputs/ndi/srt and please if you can do the combinations of the overlay channels like my photos (all on/off etc) asnd check the API what happens to the outputs info In my tests if for example i have disabled in the output 2 the 4 channel overlay,then the output 2 info is not appeared in the API and same for the output 3. If overlay channel 4 is not checked on,then the info for what output 3 is,not appear in the API  out3.png (36kb) downloaded 1 time(s). out4.png (36kb) downloaded 1 time(s).thanks for any answer
Joined: 1/13/2010(UTC) Posts: 5,208  Location: Gold Coast, Australia Was thanked: 4478 time(s) in 1561 post(s)
This has now been fixed as of latest update. However note that overlay status is not planned for the Outputs XML API at this time.
The reason being is a fair amount of resources are needed to retrieve and compile that information, and the ability to turn on or off overlays dynamically is not currently possible anyway. So we felt that not showing this information would reduce system load with impacting most use cases for this API.
 3 users thanked admin for this useful post.
Originally Posted by: admin  This has now been fixed as of latest update. However note that overlay status is not planned for the Outputs XML API at this time.
The reason being is a fair amount of resources are needed to retrieve and compile that information, and the ability to turn on or off overlays dynamically is not currently possible anyway. So we felt that not showing this information would reduce system load with impacting most use cases for this API. Hello. Understandable for the overlays. Is possible the SRT to be "true" when it is enabled and transmit and "false" when is enabled but not transmit?
Beta Discussion
