Beta Discussion
Support for Zoom Sessions/Events?
Joined: 5/7/2024(UTC) Posts: 1 Location: Uppsala Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hi and thanks for a great software!
I wonder if there are any plans to support Zoom sessions/events in the future? It is specifically the "backstage" function that we would like to use but which is not working now.
The solution right now is to run a regular Zoom meeting with all "callers" as a the backstage-room and then send the program feed to a Zoom event meeting. Messy but it should work.
Best regards, Jan Fornhem / Phosworks
1 user thanked Jan Fornhem for this useful post.
Joined: 7/31/2017(UTC) Posts: 4 Location: Ontario, Canada Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
RTMP Ingest within Zoom Sessions and Zoom Events Webinars ONLY is now available for Zoom Sessions / Zoom Events licenses.
Check the Feature Request section for my feature request of adding Zoom's RTMP ingest servers to the dropdown list of CDNs instead of currently using Custom RTMP.
If you upvote the feature, VMix may add the servers to the list.
Beta Discussion
