2 Pages<12
Roy Sinclair
#21 Posted : Thursday, September 5, 2024 7:02:58 AM(UTC)
Roy Sinclair
Was thanked: 25 time(s) in 21 post(s)
Originally Posted by: ryxyz Go to Quoted Post
1. Allow a layer source to be "flattened" so it can be zoomed and panned while preserving its location and cropping (without the need of the Mix or UVMAP workaround).
2. Add file system loading of scripts so an external editor can be used for editing a script rather than having to continually reload it from the UI.
3. Add shortcut to set the category of an input
2. Replace the recently deprecated and incompletely done vbscript scripting with a set of API calls that can be used in Visual Studio to create very fast compiled actions in any language supported by Visual Studio.
I think this would be better since it should allow a vastly improved programmatic control of vMix and the source for the programs could be stored using any version control supported by Visual Studio. Then vMix only has to support the API internally instead of supporting the whole scripting language (eventually, best would be supporting the scripts and the API for a year or two before removing the internal scripting).
An API could also post "Events" in vMix to be subscribed to, that would open the door for plugins that can do a lot of the things we'd like to see added to vMix but they need to spend their time on more fruitful projects.
knbPixels
#22 Posted : Thursday, September 5, 2024 7:24:09 AM(UTC)
knbPixels
Originally Posted by: knbPixels Go to Quoted Post
The ability to crop Zoom inputs when they are used as a layer source on another input. We can already crop video playback files in this manner, and images of course. Being able to crop Zoom inputs on layers would be great so that we don't have to use work arounds like duplicating Zoom inputs and then cropping them on the Zoom input for each different setup
By the way, I just discovered that if you apply a Key mask to a zoom input, you can then use it on a layer in another input and do cropping there. So if you make a mask that is a full frame of white, and use it on all of your Zoom inputs, nothing gets masked out, but it allows the cropping later. But it's kind of weird that you have to do that
attwwqy88
#23 Posted : Monday, September 9, 2024 11:36:04 AM(UTC)
attwwqy88
The ability to create shortcut that allows to turn the “show cursor” on or off for individual inputs desktop capture. So right now when you right click on a desktop capture input the very first option is show cursor and it’s automatically checked to begin with. I would like to be able to make a hotkey specific to the inputs that allow to turn on and off the “show cursor” option that normally appears by right clicking on the input. Thanks
Machtl
#24 Posted : Friday, September 13, 2024 12:38:18 AM(UTC)
Machtl
Austria
* Custom Output Resolutions like a 21:9 1080p output
* Multiple Outputs for EdgeBlending of Projectors
* Scopes(Histogram/Spectrum/...) of Inputs as Inputs and/or to be used as an Fullscreen Output
* More sophisticated Tally Engine for PTZ cameras. For example we use 3-4 Panasonic AW-UE150 with Vmix
via HDMI inputs. We make different Layouts/Inputs and merge between them. The Tally should reflect if a
Camera is actually used in the current Output/Preview and if its in the visable field of view. If its moved
out of the visable field of view, there should be an option to turn the tally off on those Cams.
nikosman88
#25 Posted : Friday, September 13, 2024 8:38:25 PM(UTC)
nikosman88
Greece
Was thanked: 81 time(s) in 77 post(s)
Here are some new features that vmix28 will have
thanks 1 user thanked nikosman88 for this useful post.
ryxyz on 9/14/2024(UTC)
nikosman88
#26 Posted : Sunday, November 24, 2024 4:09:44 AM(UTC)
nikosman88
Greece
After vmix 28 beta release i remembered this thread and i see what of our ideas have been implemented in Vmix 28
I would love the trigger functions in vMix to be expanded to include not only "OnCountdownCompleted", But also "OnCountdownTime" and then the options for greater than, less than, and equals to a countdown timer reaching a specific mark. I would use this for triggering actions based on the time remaining of a countdown timer.
Instead of "oncountdown time" they add "on playback time" and "on playback remaining".
1.Flatten layers is finally implemented and that goes the layer composition a lot higher
2.No un-fortunatelly
3.No un-fortunatelly
I would love the ability to either:
A) Lock the volume fader on audio inputs in the mixer
or
B) Disable the ability to use the scroll wheel on inputs in the audio mixer
I tend to use the scroll wheel to move up and down in the mixer, and I have to be very careful not to accidentally change a fader level when I scroll, it's very easy to do.
Also the scroll wheel enable/disable has been added
Originally Posted by: aps Technical Go to Quoted Post
- Split Audio Buss to Mono (16x Mono Audio Out)
- Change EQ to Semi-Parametric - Access from Audio Mixer window (pop out on channel) - Addressable via Mackie Control/SSL UC1/MIDI/OSC
- Access Compression from Audio Mixer window (pop out on channel)
- All Audio Buss routing accessible from channel in Mixer Window (smaller buttons, addressible via MIDI/OSC/MCU/Companion
- Revise Channel/fader in Audio Mixer window (double-click to 0db, double-click to -inf, Pan changed to rotary, double-click to centre)
- VU meters updated (either have them as dBfs so they clip at 0dBfs or dbVU with appropriate headroom, with faders to match)
There's a lot that can be learned from RME TotalMix FX for software mixer layout.
- Zoom Call > Isolated NDI
- On-the-fly selection of Zoom Call Video and Audio return signal
- Borders - Curently borders 'pop' on merge transitions between sizes, only when the merge animation has finished, and the border size is relative to the PiP size.
- Latency reports between input and output
- More Fullscreen outputs
- More NDI Outputs
- GT Designer improvements (like object snapping)
From this list i see as implemented the All buses button in audio mixer
When vmix 28 will be final release, i think is usefull to have a vmix 29 ideas thread and hope vmix team to use it for some new features
Simsyuk
#27 Posted : Wednesday, January 15, 2025 7:26:40 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Love to have TikTok working with vMix. I'm using TT live studio and vMix but would be nice for vMix Social to show comments. I did ask TT and they said they have no plans to work with vMix only OBS. Such a shame.
BRUNO GONZAGA
#28 Posted : Saturday, January 18, 2025 5:20:15 AM(UTC)
BRUNO GONZAGA
Brazil
Sem titulo.jpg (114kb) downloaded 3 time(s).
[img=https://1drv.ms/i/c/345875937cc17849/EXCWeK9SXAtFhgnFxQjjsPUBPucs4SpZecHJ54hR7uhsHQ?e=gHi6ex]PRINT[/img]
Como está na ilustração, editei o layout do "Title editor" para incluir seta para cima e para baixo, de maneira que possamos selecione um item e mova-o para outra posição desejada.
desde já agradeço a atenção de todos.
atenciosamente,
Bruno Gonzaga - CEO START TV LIVES
#29 Posted : Saturday, January 18, 2025 5:49:31 AM(UTC)
Was thanked: 987 time(s) in 819 post(s)
atenciosamente,
There is no need to double post . See https://forums.vmix.com/...ARA-ORDENAR--lower-third
SysProfile
#30 Posted : Monday, March 10, 2025 10:57:47 PM(UTC)
SysProfile
Argentina
Update datasource functions
Examples:
Code:
API.Function("DataSourceSetURL", Value:="DataSourceName,new value")
Code:
API.Function("DataSourceReadRow", Value:="DataSourceName,row number") 'Return a String Array
API.Function("DataSourceReadCell", Value:="DataSourceName,row number:column name or number") 'Return a String Value
nikosman88
#31 Posted : Tuesday, March 11, 2025 9:46:04 AM(UTC)
nikosman88
Greece
Separate recorder shortcuts. So one can start-stop record 1,2 or both.
2 Pages<12
