It would be great to have the ability to show a Zoom participants hand raise in the live input. Hand raise information is obviously being sent to VMix, when a Zoom participant raises their hand, this is being shown in the input preview window in VMix with a Blue bar along with a message in the Zoom manager which is great for the TD. I havent figured out a way of showing that in the live output. Currently, what we do is use a companion emulator which we provide to each guest. The emulator simply switches on (or off) a VMix layer on that guests input which either shows or hides a little hand gif. This works really well but it means that guests need to have another window open and we also need to manage multiple emulator links which is painful.
Having the ability to show the Zoom hand raise in the live output on a per guest basis would make for a great feature. Failing that, providing the ability to use the data that is obviously being sent to VMix from Zoom to switch on or off a layer to achieve the same result would also work.
Has anyone managed to find a way to do this?
