VST3 plugins aren't shown correctly - help
Hello folks! some VST3 plug-ins don't fit/scale correctly in their window. They show up cropped to the editor window size so some functions are out of view and unavailable. I added 2 examples in the link. My other plugins show up fine, and I haven't encountered it mentioned anywhere else in the forums, please help. example 1
[img=https://drive.google.com/file/d/1mfT_qlqkVwXKhROdbOQcszysm7n2ilYX/view?usp=sharing]example 2[/img] screenshots (in drive folder):| 2 VST examples
Hello @Streampunk, The images are not available, and I'm unable to open them. However, I understand the issue you're describing. Based on my own experience, I encountered a similar problem when transitioning from VST2.4. I've started researching the issue and discovered a huge difference between VST and VST3, It seems that not all developers are fully prepared for this transition. I recommend reinstalling the plugin, but consider trying an alternative or possibly an older version.
