NDI
Help! POE switch for live production- need to choose
Can you help or suggest a list of good 8 ports plus switches with Poe that I should buy to use with NDI cameras and multiple NDI laptops?
Definitely unmanaged as it will be used in clients locations. Also, i was told with a minimum speed capacity of 120gigabits.
Im good at many things but when it come to network, not my forte. Budget £500 or less.
Joined: 4/23/2017(UTC) Posts: 1,030  Location: Germany Thanks: 3 times Was thanked: 150 time(s) in 132 post(s)
Netgear AV line switches. HP or ZyXel should do as well. If you know RouterOS and won't mind using it, Mikrotik would be an option as well. But if you don't know it and networking isn't yours Mikrotik is nothing for ya.
1. TP-Link TL-SG108PE 8-Port Gigabit Easy Smart Switch with 4-Port POE - £33.99 2. Netgear GS108PE 8-Port PoE+ Gigabit Ethernet Unmanaged Desktop/Rackmount Switch - £54.99 3. D-Link DES-108 8-Port PoE Gigabit Unmanaged Desktop Switch - £48.99 4. Netgear GSS108E 8-Port Gigabit Ethernet PoE+ Unmanaged Plus Switch - £76.99 5. Ubiquiti UniFi 8-Port 150W PoE+ Gigabit Switch (US-8-150W) - £125.00 Machine learning in ecommerce is an increasingly popular tool for businesses in the ecommerce space. It can be used to improve customer experiences, optimize pricing strategies, personalize customer service, and more. Machine learning algorithms are used to analyze large datasets in order to identify patterns and correlations, which can then be used to help companies make more informed decisions about customer engagement, product development, and promotions. Additionally, machine learning can be used to automate processes that would otherwise require manual intervention, making them more efficient and cost-effective.
NDI
