	Tik Tok RTMP error (Resolved)
 Joined: 4/26/2020(UTC) Posts: 38  Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
                We have been streaming to Tik Tok via RTMP from vMix for over a year with no issues until today. Re-generating the Tik Tok key several times did not solve the issue. Streaming to the same account from OBS worked fine.
  Any ideas what this error might mean? "Operation not permitted" seems like it might be important...
  FFMPEG1.Exited   Metadata:     encoder         : Lavf57.82.101     Stream #0:0: Video: h264 (h264_nvenc) (High) ([7][0][0][0] / 0x0007), yuv420p, 720x1280, q=-1--1, 2500 kb/s, 23.98 fps, 1k tbn, 23.98 tbc     Metadata:       encoder         : Lavc57.106.101 h264_nvenc     Side data:       cpb: bitrate max/min/avg: 2500000/0/2500000 buffer size: 1250000 vbv_delay: -1     Stream #0:1: Audio: aac (LC) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, fltp, 256 kb/s     Metadata:       encoder         : Lavc57.106.101 aac [rtmps @ 0532de20] Server error: func:OnStatus:func:RtmpStatusCode2NssError:invalid_sign av_interleaved_write_frame(): Operation not permitted     Last message repeated 1 times [flv @ 05327600] Failed to update header with correct duration. [flv @ 05327600] Failed to update header with correct filesize. Error writing trailer of rtmps://push-rtmp-f5-tt01.fcdn.us.tiktokv.com:443/game/stream-3569620611980853532?expire=1652489396&sign=5873832409d130e8e18e609c5772d80d: Operation not permitted frame=    6 fps=0.0 q=12.0 Lsize=      40kB time=00:00:00.23 bitrate=1397.8kbits/s speed=0.68x     video:52kB audio:6kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [aac @ 0532c5e0] Qavg: 256.401 Conversion failed!
                Update:
  Streaming from vMix is now working, with identical settings and no change in hardware or software configuration. I have to conclude that it was a Tik Tok issue, though they claim it must have been vMix's fault.
  It's still a mystery to me why OBS worked that day and vMix didn't.
