Ticker object settings reset after save/close
Joined: 5/1/2020(UTC) Posts: 10  Location: Tennessee Was thanked: 1 time(s) in 1 post(s)
I've been struggling with this for a while now and can't seem to find a resolution. When I add the "TICKERHD3.Xaml" from the titles Input to a broadcast, add content to that ticker and then save and close that project and re-open the project. That object has reset the text to the "Lipsum" generic text as well as reset the font and size. Causing me to have to re-populate the ticker text and correct the font and size. (the XY positon is unchanged). Has anyone else experienced this?
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 49 Location: Canada
Hi MSFTGuruGuy
You need to pause the ticker before you save the preset in order for the text to be saved, otherwise, vMix will not recognize or save the moving text.
vMix Greg
The Preset bar at the top left hand corner of vMix is where you can quickly save your production, including Inputs, recording and streaming settings to file. This Preset can then be recalled again at a moments notice. MIBridges
