Instant Replay
Shortcut for "Play Each angle of selected"
I recorded an event with four cameras. To play back this last event with all four angles to output immediately one after the other I can select "Play Each angle of selected" from the replay main window - perfectly. Is there a shortcut for this operation? I tested two shortcuts, but without the effect wanted. For shortcut with "ReplayPlayLastEventToOutput" only the first camera angle will be replayed. With "ReplayPlayAllEventsToOutput" all events in the list will be replayed.
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
To play back this last event with all four angles to output immediately one after the other I can select "Play Each angle of selected. RealcompOnline
Instant Replay
