max76
#1 Posted : Thursday, November 19, 2020 10:06:21 PM(UTC)
max76
American Samoa
I opened up a window (ran "run" and typed dfrgui) that was supposed to tell me if I had an SSD or HDD, and what I saw was:
(C:) Solid State Drive
New Volume (E:) Solid State Drive
New Volume (F:) Hard Disk Drive
I do not know a lot about technology, does this mean I have an SSD or HDD.
192.168.o.1
192.168.0.1
tp link login
slxxi
#2 Posted : Thursday, November 19, 2020 10:46:33 PM(UTC)
slxxi
Solid State Drive = SSD
Hard Disk Drive = HDD
So C: = SSD, E: = SSD, F: = HDD
vitabuel
#3 Posted : Wednesday, April 6, 2022 7:00:12 AM(UTC)
vitabuel
Canada
Do you know the difference between these two drives? While traditional HDD type storage is cheaper to buy, it is much slower than SSD type storage. The easiest way to check the type of Hard Drive or storage installed on a computer is to open the Defragmenter or Optimize Drives utility. Be careful with your data when checking because you may accidentally delete it. If this happens, don't panic. Any data can be recovered. Although the process is not very easy, it is possible. If you lose your data from your hard drive, I suggest you use the services of salvagedata.com.
